Версия прошивки от Arto с XDA-Developers.
Автор прошивки считает, что этот ROM самый быстрый и стабильный
[О прошивке:]
- Последние драйверы acer 3.003c
- Последняя версия WM 6.5 21xxx (Классический интерфейс WM "пуск вверху") и 6.5.x 235xxx (Новый интерфейс WM панелька с большими кнопками "пуск внизу")
- Sense 2.5 последняя сборка 2013
- Некоторые полезные инструменты : Icon changer, inf changefont, bsb tweaks, touchx soft reset and wifi
- Меню "Пуск" почищены
- HTC сообщения 100% рабочие
- Новый отличный звук, при нажатии кнопок Позвонить и Конец
- Работает вибрация в приложениях HTC
[Примечания:]
- You will see some acer cabs installing during first boot please let them installing !!!! that not acer cabs but mine
- When bsb tweaks ask for a soft reset you get an error thats normal skip this error , soft reset and your settings are applied
- Calculator is in office folder
- If you have bluetooth headset, handfree doesn't work, to resolve this, desinstall srs wow hd and srts bluetooth enable in "remove application"
- If you want mms working, you have to configure the mms server settings manually and dependantly from your operator
- Delete application data in the root of your sd card to prevent issues with docs tab and HTC sense freezes
- "experimental" If you want to get more free ram you can disable the windows Start menu (you will get 20 mb to 30 depending of your icons) but be carefully ! if you disable sense in today settings make sure you map a key to resco explorer or something wich allow you to get in your shortcuts ! if not, you don't will be able to go in your today settings and reenable sense ! Manila start menu works only when sense is enabled ! the best things you can do is to do'nt disable sense (if you install a sense mod, just do a soft reset, it works the same) the cabs are below
Download ver 3.1 WWE
Arto's Sense 3.1 WWE (3.003c drivers, 23123, 2015) - пуск внизу.
Download ver 2.9 WWE
Arto's Sense 2.9 WWE (3.003c drivers, 21095, 2013) - пуск вверху.
Log
1.1
- removed opera 10
- rearranged the start menu
- made some registry changes
1.5
- ported the 21895 build
- you have now to enable sense in home settings after the first boot (acercustomization is the cause)
- extrom functional with acercustomization and preference.cab integrated
1.6
- removed some unnecessaries htc packages to get more ram and space
- removed youtube package since it does'nt work properly with our s200
- fixed the low performance in 3d (with games)
- the device appears to be more responsive
build 23545
- very fast
- electopia does'nt work > maybe other games too
- task in connection settings does'nt appear
-can't read emails when open one in manila or windows mail....don't know why
build 23547
- removed flashlight
- added landscape mod for manila
- added 1% battery
- games work properly
- fixed the sensor settings
- fixed mails
- fixed calendar and alarm in manila
- fixed task in connection settings
- not fixed band switching in phone settings
- yes it's very fast
1.7
- added ezinput to have a rom more ready to use
- htc messaging is more stable (no hangs for me since I rearanged it)
- band switching still not work (please tell me if it happens on other builds or other roms)
- phone canvas fixed (no ugly background behind the sip icon, thx to SergeyLAR!)
- added htc voice recorder
1.8
- build 23549
- fixed fm tuner
- adding ezinput cab make the device not boot
- fixed camera button
- I hope this version is the most stable of my roms, please confirm me
1.9
- build 21898
- removed e reader tab (=more space and more ram)
- fixed the backlight settings
- added the htc mp3 trimmer
- added a working htc volume control (!)
- fixed the band switching
- added my phone
- added acer satellite data update
1.9.5
- fixed the camera
- fixed wake up issue (but must be tested in long term)
- fixed some 3d components
- fixed the phone pin which not show when activate phone
- fixed the voice recorder
2.0
- build 23551 (more stable than 23554)
- fixed the wake up issue that occured in 1.9.5
- fixed google map crash BUT, like htcsensorsdk.dll was the problem, I removed itso you have to add it in your windows directory if you want play games like resco bubbles
- removed completly the footprint tab
- PLEASE DISABLE YOUR PIN BEFORE INSTALLING this rom to prevent a pin dialer issue, of course after flashing the rom you can re enable it
- the htc menu enhancement works great, I added too the francarl htc menu loader to have sip menu and htc message box enabled
- htc volume control does'nt work on 23xxx so I removed it
- removed voice recorder because does'nt work anymore and anyway it's not useful compared to audio notes touch
- htc location service appears to be more stable then more fast (think it was the same problem than g maps)
- added the bluetooth icon thx to riotman
- changed the battery % icon and pin dialer
- fixed the graphic issue in internet explorer (with 23xxx builds)
- fixed airplane status in comm manager
- fixed facebook online album
- added the livven theme
- 207 mb of freespace
- more fastest than all previous releases, you will see the difference
2.1
- fixed the lef/right arrows intervertion in 23551
- added connectionwizard.cab to the extrom to make data connection working !
- changed the bluetooth icon in taskabar (with a nicer one)
- internet folder in start menu has finally its icon !
- added SRS WOW HD 1.5.1.0 in extrom since there is no more wake up issue with it, so enjoy your music
- Added marketplace (it works finnally)
- for some reasons cleartype is finally enabled in landscape mod too
build 23554
- Memory leak is fixed with this build so it have more ram than 23551
2.3 Build 21899 FR
- passй sous la build 21899 pour avoir le volume htc
- traduction document tab fixйe (merci a bosphor)
- grand nettoyage de printemps pour libйrer de la ram et de la memoire interne donc j'ai retirй des tabs qui sont superflues а mes yeux : twitter et bourse, йgalement retirй le clavier htc qui me sert а rien, mais si vous l'utiliser il ya des cabs disponibles sur le forum
- du coup il y a 220 mb dispo
- menu dйmarrer propre avec les icone HQ
- mise а jour de package htc, le sense devient plus fluide
- problиme de scrolling avec s2u2 rйsolu !!! j'attend vos cris de joie
- srs fonctionne (problиme de wake up issue avant dans les 21xxx)
- lecture des videos а partir de l'album merci а ocman pour l'astuce) par contre il faut activer htc video player dans le gsensor settings pour voir les vidйos en mode paysage
- wifi router dans le comm manager fonctionne a merveille
- Dossier de flashing mis а jour (merci а stefano et lightandrose)
2.4 build 21901 EN
- build 21901 to have htc volume control
- updated office mobile to the 2010 one from the build 23563
- I made a Big cleaning in the htc packages, that mean :
- removed twitter tab since I find it useless
- updated htc messaging, framework, dshow, and others to the latest version
- removed ezinput since I don't use and some of you too, you can always find cabs in this great forum
- the slider of sense is more fluid
- srs works on 21xxx builds (before there was wake up issues)
- S2u2 scrolling issue is solved !!!!! enjoy your favorite wallpapers
- wifi router button works well in commanager
- flashing folder up to date (thx to stefano and light and rose)
2.4 build 21901 FR
- mкme composition que la version anglaise
- l'onglet bourse est rйintйgrй
2.4.5 build 21901 FR-EN
- htc messaging issue fixed edit : not fixed as the flash.bin was not the good..
- added some registry tweaks to have manila start on first boot and no error reporting, thx to brainmaster !
2.5 build 21901 EN
- Htc messaging REAlly fixed now (I tested it)
- updated google map to 4.1.0
- some uselless things removed, 5 mb recovered
- livven theme added by defaut (thx to brianmaster !)
- updated htc packages with the news from leo rom 2.11
- removed some icons in start menu
- fixed the issue when phone pin didn't appear in the first boot
2.5.1 build 21901 WWE-FR
- fixed the issue when you get a grey window when want change date, time or with some others messages
2.7 build 23568, 21903 WWE
- build 21903 and 23568
- added wifi adhoc fix
- added htc voice incall recorder
- updated many htc packages
- ezinput readded to make htc messaging working stable
- Manila is CFC compressed (thx brainmaster for the idea) it seems, that sense is more fluid and fast and it give more space
- optimized space !! (230 mb free )
- updated some start menu icons
- added volume keys for 235xx
2.8 build 21903 WWE-FR
- Updated to 21903 build
- Updated some htc package from the new leo rom 2.13
- htc messaging is updated (to 2014) and is more responsive
- music engine updated (some changes but I don't know what exactly..
- document tab updated (more responsive)
- satellite update has now an icon in outils folder in fr rom
- replaced csmi with jw icon changer (more options)
- updated francarl htc menu enhancer to 1.4 (message box really more responsive)
- readded htc voice recorder
- changed the size of the scrollbar (very practice in adobe reader)
- you can use your camera with ezinput enabled thx to stefano for his tweak
2.8 build 23568 WWE-FR
- same as build 21903
- htc volume is'nt included
2.9 build 21905 WWE-FR coming soon
- updated to build 21905
- Updated the manila core to 2013 ! and some tabs
- corrected camera mui file name (thx to ocman for the notice)
- normally mms receiving is fixed please let me feedbacks (thx to ocman for this fix)
- busy sound when calling has been changed with a nice one
- Office mobile 2010 integrated
- deleted some uncessaries things
- corrected text in document tab and others places in french version
- readded htc sensor dll since google maps does'nt crash anymore
- some things I forgot
- update album art fixed
- The stability and speed has been really improved on sense
2.9 build 23569 WWE-FR
- same as 21905
- fixed again the dial sip icon in 23xxx build
- removed voice recorder (does'nt work on 23xxx)
- ok 23xx is finger friendly but I get many things which don't work properly : some applications lose their menu, htc volume does'nt work, voice recorder too, some buttons are not skinned by the livven theme (and others) so if you want a stable and fully working rom, try the 21905
3.0 build 21907 WWE-FR
- Updated wm build to 21907 > don't know what changed though
- Updated manila core to 2015 > GREAT improvment in speed and loading tabs !
- Updated all tabs to 2015-2016
- Updated liven theme
- Updated htc menu loader to 1.41
- Updated htc messaging to 2016
- updated a lot of package to the latests (dshow, ezinput, menuenhancment, notification enhancement, etc, etc)
- Added the coverflow feature (press on the title of the music-photo tabs and you will see a nice animation) A big thanks to rotastrain for his lua script (which I modified though and fixed, this was an hard work !)
- Fixed the lockscreen (now it's the wm 6.5 lockscreen and not the 6.1) but you have to know that the 6.5's one takes 3-4mb of ram when enabled
- Fixed the mms receiving (thx to fulat and ocman for finding how to fix!!)
- Fixed the gps signal lost (acer fix implemented)
- Fixed the message box when you see "all process done" in acer installation
- Updated windows live to 11.1 and placed as a cab (removable)
- Updated Extrom with the great tools of stefano !thx to him
- Removed Streaming player (useless)
- cleaned up the oemdriver folder
- Cooked with the new kitchen provided bt stefano thx to him !
3.0 build 23123 WWE-FR
- Same as 21907
- htcvolumecontrol removed
- new notification enhancement with task manager btn
- Htc menu fixed in 23xxx builds : it load now from the bottom
- Phone canvas is totally fixed : caller id, incoming position and sip icon are fixed
- no bold font on ezinput and others
3.1 build 23123 WWE-FR
- resolved the ringtone issues and wallpaper change
- readded voice recorder as it works again now 8)
- Readded streaming player
- some minor things
Оригинальная тема
- removed opera 10
1.5
1.6
build 23545
- very fast
build 23547
- added 1% battery
- fixed mails
1.7
1.8
- build 23549
- fixed fm tuner
1.9
- build 21898
- added my phone
1.9.5
- fixed the camera
2.0
2.1
build 23554
2.3 Build 21899 FR
2.4 build 21901 EN
2.4 build 21901 FR
2.5 build 21901 EN
- same as 21905
- Same as 21907
- some minor things
Оригинальная тема
Как войти в режим прошивки
Для прошивки с версии 2***:
- Выключить КПК длительным нажатием на кнопку Питание
- Запустить прошивальщик ACER_EUU.exe и следовать его установкам до окна с предложением нажать кнопку камеры и питания
- Зажать только кнопку Камера и не отпуская ее подсоединить КПК к ББ (должен замигать красный светодиод)
- Прошить Кпк, дождавшись сообщения о успешном обновлении (красный светодиод должен гореть не мигая)
- Включить КПК кнопкой Питание. После включения КпК дожен сам сделать ХР
- Согласиться с установкой Extrom
Для прошивки с версии 3***:
- Запустить прошивальщик ACER_EUU.exe и следовать его установкам до окна с предложением ввести кпк в режим прошивки
- Зажать Камера + нижняя громкость + питание. Удерживать все три кнопки (должен замигать красный светодиод).(соблюдаем последовательность нажатия)
- Подключить КПК к компьютеру (важно, чтобы ББ увидел Ваш КПК)
Вход
Регистрация
Помощь
Тема закрыта
Ответить
Наверх
К списку форумов
Очистить cookies
Отметить все сообщения прочитанными
